I have a lot of headphone units that after years of abuse in the studio need cable replacement.
I already took care of the speaker replacement in the units that needed it but I would like to replace old and intermitent cables with new and longer cable.
I tried in some units to replace the cable with nice mogami thin microphone cable (2 conductors+shield), I used each conductor for the + signal in each channel and I divided the shield for both - signals in each channel.
The sound of those units is much worse than before with the intermitent but original cable.
What type of cable are you guy using to replace on headphones? what is your advice?
I preffer to buy someting in bulk as I can then make it a big longer than the cables from the manufacturers, also it's less expensive when replacing cables in 10 units
Thank you
Thank you
