pahstah Well-known member Joined Sep 8, 2005 Messages 276 Location Italy Nov 30, 2016 #21 No, they're not. If i remember correctly the center of the pots is 1mm farther from the panel's edge than the switches center
ruffrecords Well-known member Joined Nov 10, 2006 Messages 16,309 Location Norfolk - UK Nov 30, 2016 #22 pahstah said: No, they're not. If i remember correctly the center of the pots is 1mm farther from the panel's edge than the switches center Click to expand... That is so annoying but I guess 1mm is not enough to worry about. Cheers Ian
pahstah Well-known member Joined Sep 8, 2005 Messages 276 Location Italy Nov 30, 2016 #23 Well, if it is important to have the centers aligned you can partially inserì the switches until they align with the pots and then solder them in place, not very elegante but can work
