I don't care what those albums sound like. I wanna DIY a Helios because THEY'RE ******' COOL! :razz: :green:
It's not gonna be germanium amps. They just run on a negative rail because they use PNPs at the input. It should be possible to 'flip it' and make it run +24V with NPNs instead, but I don't see the point. There's no need to be afriad of a little negative voltage
The two amps are identical and pretty low tech. Since the EQ is totally passive you could use whatever you wanted.
I _think_ (because I have never heard or used that Helios) the sound is in that Lustraphone input trannie and the EQ schematic. So, if Sowter makes a decent sub and we can get the 'right sounding' inductors, I'd say we're very much in the ballpark. Sure, the amps are a part as well (and the PSU :green: ) but not a major player. Again, that's just what _I_ think. There's so much urban myth, that I could be totally off my rocker :shock: :?
I would have no way to check though, 'cause there aint no 69 Helios in my neighbourghood.
That famous 1dB @ 100Hz bump is probably due to the input trannie, or what? It's supposely still there with the EQ in bypass. I don't think the amps are boosting half a dB each. Anyway, I don't think it's that important... or is it. What do you guys think?
Also, I think the one to clone is the original 69 not that reissue. That looks quite different, new hi/lo-pass filters, totally different amps, two active buffers and more taps on the midrage inductor. And much less mojo/coolness factor, imo
Soooo.. anyone wanna help out with those EQ values :wink:
