midwayfair
EDIT: Got it worked out when the front membrane is polarized. See my picture a few posts below this.
Sorry this is so long, but I wanted to get a handle on this BEFORE I mess something up beyond repair.
Trying to work out two things:
1. Make sure I understand how polar pattern switching operates.
2. The simplest way to implement figure 8 and omni patterns using a capsule without isolated backplates in a mic running on straight phantom power.
In most cheap tube mics, it's simple:
Like the 460: http://www.deeringamps.com/workbench/images/apex460_mic_lg.jpg
Backplate is held at B+V -- this is the primary output.
Front membrane is at 60V.
Rear membrane is at 120V in figure 8, 0V in omni.
It looks like I don't actually need any way for sound to go from the rear membrane to the input of the mic, just change the voltage relationships. How does the signal get from the rear membrane to the front?
RM - BP - FM
Omni: 0 - Med - 0
Card: 0 - Med - Med
8: 0 - med - hi
When the front membrane is as much higher than the backplate as the backplate is above the rear membrane, the phase of the membranes is reversed. So it looks like I can't use this switching with phantom unless I polarize the backplate to 24v. I don't like that idea much.
In the U47-N, it's even simpler -- the rear membrane is simply shorted to the front! Nothing even to drain off voltage when switched back to cardiod.
RM - BP - FM
Omni: 0 - Med - 0
Card: ? - Med - 0
No figure 8 available here, but the switching is easiest.
In the u87i, it's different and looks more complicated:
http://cdn.recordinghacks.com/images//mic_extras/neumann/U87-schematic.png
One main thing here compared to the other schematics is the addition of a capacitor from the rear membrane to front membrane. This makes it look more like two capsules smooshed together instead of one capsule with two membranes.
Front membrane is held at 0V through R6.
Front backplate is held at ... uhh, it's complicated and I'm not exactly sure. Something less than the 48V from phantom. There's a 33V zener in there, but is that doubled to 60V? I know it's doubled in the Ai based on a recent question I asked. Anyway, I'll call it the "polarization voltage" and just use percentages of it.
Rear membrane is connected to the front backplate's same polarization voltage except that it's got 1.68G between them. I assume that it's not drawing any current, so in cardiod the polarization voltage is actually the same between the front backplate and the rear membrane, and the exceptionally high resistance is to keep it separated from the voltage created on the front membrane.
Rear backplate in cardiod is connected to the front backplate through 68M, so it's at the same polarization voltage. This makes the two backplates look like one.
In figure 8, the rear backplate is switched to about half of the polarization voltage (a pair of 68M between the polarization voltage and the 300K to ground).
In omni, the rear membrane is polarized through a 1G to the 0.4% polarization voltage, and BOTH rear elements are at the same polarization voltage, so everything except the front backplate is now near ground.
Okay, that does actually mesh with the other switching schemes where in omni everything except that instead of switching the polarization between ground and half, we've switched to something slightly above ground and something slightly below half. And the Figure 8 is switching the back to half voltage instead of double. Same principal.
RM - RBP - FBP - FM
Omni: ~0 - ~0 - Hi - 0
Card: Hi - Hi - Hi - 0
8: hi - med - hi - 0
I'm having a hard time seeing how the back is exactly out of phase with the front. From this, it looks like the back half of the capsule is only 90 degrees out of phase with it. What gives?
Now let's say I have a capsule without isolated backplates in a circuit that doesn't already have a polar pattern. What's the simplest way to do the switching?
I need to polarize one thing, have another thing at ground, and switch the third thing between 1/2 polarization and another voltage.
I'm going to use this, because it actually has space for more switches and just needs a bit of metal nibbled out of the body to poke through:
http://aurycle.com/manual/a460-diy-schematic.pdf
Ignoring some different resistor and capacitor values, this has the front end of the u87 minus the polar pattern switching and necessary components, and the polarization voltage is the 48V from phantom instead of whatever it is in the 87.
The kit comes with a capsule without isolated backplates. (I'm not totally sure what the capsule is in the current kits as it's different from when they first started them, but i think it's the same one in the MXL920 -- that is, 67-style but the 32mm membrane.) My alternative was a 47-style capsule, in part because I have one on hand.
Here's a diagram I drew (it's large so I didn't embed it) of some possibilities:
https://dl.dropboxusercontent.com/u/9878279/Jon%20Patton%27s%20layouts/Circuit%20ideas/Polarization%20possibilities.png
Proposed Method 1
Sort of like the cheap tube mics, but some things are mixed up. Adds two resistors and that's it. I don't think this one works -- the mic input is the front membrane here instead of the backplate like it is in the cheap tube mics.
Backplate is polarized, input connects to front membrane, which is at 0V.
1. SPDT on/off/on switch
1 -- Omni. Connects to ground like in the cheap tube mics. Or the polarization voltage instead? Does it matter?
2 -- Connects to the rear membrane (does it need to be through a large value resistor?) Off in the center: cardiod.
3 -- Figure 8. Connects to center point of 68M/68M voltage divider between the polarization voltage and ground.
Here I'm going:
Omni: 0 - hi - 0
Card: x - hi - 0
8: med - hi - 0
So this doesn't have the "medium" voltage in the middle for figure 8. However, it does look a little like the 87 minus one of the elements.
Proposed Method 2
Same as above, but instead of connecting the rear membrane to a 0V point directly for omni, it shorts it to the front membrane like in the 47-N schematic.
Still not sure this works:
Omni: 0 - hi - 0
Card: x - hi - 0
8: med - hi - 0
The end result is the same as above.
I am more confident that the omni mode works, though.
Proposed Method 3
This is more like the 87 but ignoring the second backplate.
1. Add 470pF cap from the rear membrane to the front membrane.
2. SPDT on/off/on switch
2 -- Connects to the rear membrane through a 1G. Center off (cardiod)
Omni: 0 - hi - 0
Card: x - hi - 0
8: med - hi - 0
Not really sure what happens here. There's a clear path to the microphone output from both capsules, so I am not worried about that. The omni should work the same as in the 47 schematic, because both capsules are at ground potential, so they're in phase. I just can't figure out if the figure 8 pattern's produced.
This leaves out some components that appear in the 87, like a 10pF cap and the 300K from the switch to ground (not sure exactly what that's doing).
Method 4 -- not drawn
Polarize the backplate to 24V instead and switch the backplate between 0, 24, and 48V. Avoiding this because it loses a lot of sensitivity in all patterns.
Again, I'm sorry this is so long, but I've tried to be as clear as possible.
RM - BP - FM
Omni: 0 - Med - 0
Card: 0 - Med - Med
8: 0 - med - hi
RM - BP - FM
Omni: 0 - Med - 0
Card: ? - Med - 0
RM - RBP - FBP - FM
Proposed Method 1
Here I'm going:
Omni: 0 - hi - 0
Card: x - hi - 0
8: med - hi - 0
Proposed Method 2
Omni: 0 - hi - 0
Card: x - hi - 0
8: med - hi - 0
Proposed Method 3
Omni: 0 - hi - 0
Card: x - hi - 0
8: med - hi - 0
