Hi fellow mates,
for my Live Sound work and duties I have many times Keyboards, Samplers, Drum Machines and Roland SPDS instruments.
All of these instruments have unbalanced Line Level outputs which fall into the -10dBV consumer Line Level.
The signal in already Low Impedance so there's no need for an Hi-Z input like Instrument Level.
I need to build very simple boxes to interface these instruments to the FOH console Balanced Mic Inputs.
Normally I use DI Boxes from the local PA company, but as those DI boxes are different every gig they range from alright to pretty bad or non-working/malfunctioning. So for next year I want to start using only my devices, so I can have more consistency from gig to gig.
Also I don't really need all the commodities of a DI box for these type of instruments, no need for an Hi-Z input, no need for Galvanic isolation (so no need for transformers), and might be fine without any attenuation or step down.
What I use sometimes and works well, and that would be preferable for me if it didn't have it's short-comes would be to use a Jack TS to XLR cable (Pin 3 connected to sleeve). By the way for those not familiar with Live sound, all inputs on stage to the console use XLR connectors and connect directly to the console's Mic Preamp.
This cable works very well, no circuit is connected in the middle of the signal so it's quite transparent, but there's 2 downfalls:
- The instrument output is not protected from Phantom Power if by accident it is turned on in that particular channel
- Also the signal is unbalanced all the way, and in a sub-box on a stage the signal can have 30 meters of cable or more before it reaches the Mic Preamp's input, all those meters of cable are traveling side by side with lighting equipment, mains electricity and RF so they are prone to external interference/noise.
Example below:
So here is my goal, and I really need you guys to help on this and I'm only a Sound Engineer and not as educated in electronics design as you guys.
I would like to do a circuit that:
- it's really small (as small as possible as I will be traveling), ans possible of having a small box with 4 or 6 of those circuits inside.
- Converts -10dBv unbalanced Line Level to Balanced
- completely transformer-less
- it's the most simple and basic circuit possible, with the least amount of components
- and now the hardest part, that works solely on Phantom Power
Example below:
