sonolink
You wire those in series to get 30vac and then regulate down to 24vdc with a 7824 kinda thing?From the datasheet, 100mA max across the unit (ie both channels putting out +22dB into 300 Ohms). In my builds I tend to use 2x15V / 30VA toroids paired with a Silent Arts FP48PSU board, if that helps, though that's with relays and LEDs and such as well.
Of course.On a side note, I was intrigued by your note about a bipolar V372 above. Having worked on a few TAB V372 modules, I've never seen one with a negative power rail - as with most (all?) German broadcast modules I've seen, they were all +24V. Can you share a link? Thanks!
Tab V372D schem attached
