sonolink
Mmmm ok.....how about this?
https://es.aliexpress.com/item/4000...1000023.3.ee46a2dbw2sghY&gatewayAdapt=glo2esp
Given that you'll be hooking this up to your mains supply, my view is that the power toroid isn't the place where I'd look to cut corners. It might be absolutely fine, but for under $3 you do have to wonder.
Edit: also, that's an EI transformer you've linked there - from what I understand, they radiate much more in the way of magnetic fields than toroids (IE induced hum in audio transformers), which is why toroids are seen more often.
Toroids are not the panacea we'd like them to be... Sure they present much less magnetic leaks, but they have a much greater bandwidth which means all the HF and digital garbage that might be present on the line will not be as well filtered as it is in a 'crappy' EI transformer...also, that's an EI transformer you've linked there - from what I understand, they radiate much more in the way of magnetic fields than toroids (IE induced hum in audio transformers), which is why toroids are seen more often.
