Hello,
I am currently building a km84 type mic from https://halfshavedyaks.xyz/pcb/rect-tx.php
I have modified the circuit by changing the C7 decoupling capacitor to 47u. I am also using an electret capsule so I have removed C5, C6, R10, R11, and R12. I have used a 0.47u PP film capacitor as the coupling capacitor at C1. I have also used a 6.8p capacitor as the charge capacitor at C4. There is also a mistake on the schematics where the jfet intended to be used is a J305.
I have an issue where there is 0 volts at the source, 2.35v at the gate, and 28v at the drain. The bias trim does not change the voltage at the drain or source. Otherwise, the voltages are correct at every other point in the circuit. I am getting 29v before R1.
When injecting a test signal into any point in the citcuit I do get output. I do not get an output with a microphone capsule.
I have rebuilt the circuit multiple times, checked for shorts to ground, removed and tested every component individually, swapped out the jfet multiple times, and tried different capsules. This has led me to believe that there is something wrong with the modifications I have made or the original schematic.
Any help would be greatly appreciated and please let me know if there is any other information I need to provide.
-Sky
-Sky
