moamps
Yes.
Find the zenner diodes on the PCB and take off one leg each, then try the preamp. As Ike suggested, try to find a signal source that you will connect to the XLR input as a test signal. It can also be a signal from a sound card, in some software you turn on the generator at about 440Hz (phantom shold me off).
I didfind a designation (name), ask google
The orange ones are glass diodes, which can be Zeners, or just plain old diodes. The best thing is to try and read the number off them and look up the value. All diodes (that I'm aware of...) will start with 1N followed by a 4 digit number (usually!). So, 1N4148 is a glass, 1/2 watt rated plain old diode, 1N4728A is a 1 watt rated, 3.3v Zener and they can come in glass or plastic bodies. Just to fill you in a bit on diodes...I did
And the pic Google shows is an orange diode. But since this preamp is quite old I just wanted to make sure the grey diodes are not zener, or maybe not all orange diodes are zener...
If the orange ones are zener diodes them there's only 3 on each board![]()
