sonolink
Hi guys,
Sorry for the delay, I was away gigging.
I decided to replace the caps since most of them were "recycled" so they could have been overheated or just toasted when unsoldering them. So to be certain, I replaced all the caps on the board and connected the unconnected opamp half as suggested by usbdevice.
The volume loss seems to be gone, so that's working fine.
BUT I still have 2 issues:
-the Gain pot is still scratchy
-there's an overall hiss. It's not very loud but it's there. I tried with a different tube (an ECC81 instead of an ECC83) but there's no difference.
This thing actually sounds quite good but I think it has got a HUGE output, so maybe there's a signal o noise ratio issue and I should tame it a bit?
I hope that makes sense
Here's another recording for your ears
Guitar is a Strat on bridge position. First clean sound, then both diode overdrive positions, after that the scratchy pot, then I change to neck position and finally with the Gain to about 12 o'clock. Here you can tell how powerful is its output.
View attachment GTR01.mp3
I took a pic also for you to see the settings. Any ideas most welcome
Sono
Sono
