beatsnblunts
Active member
Hello all and thanks,
im pretty limited in the scope of electronics- ive built some kits and do some simple repairs so id appreciate some help from you’ all.
i have a aphex 661 that got drop on its face which snapped off all of the pots from a misfortune fall. easy enough for me to re solder new pots in but im having a hard time trying to source the pots on digikey. is there a standard used by manufactures to indicate size and form factor? i get the resistance/taper markings, just not sure of fit size. is it just a matter of looking for documentation per manufacture?
thanks for your time!
-S
-S
