I doubt Noble (or anybody) manufactures inexpensive pots in Japan... they may design them in Japan but generally manufacture in mainland China to be cost competitive. A couple decades ago Alps (major Japanese pot maker) moved production to Brazil in an attempt to be cost effective, since then they moved their production to mainland China.Came across this...
https://messageboard.tapeop.com/viewtopic.php?t=75894
Those are Noble pots made in Japan, I used them on the Rhodes Mk7 pianos.
Yes, Aphex still has stock of these parts. Unfortunately, the new owners are rather dense when ordering these parts. Therfore you must be thorough and double check the order. I would also send Aphex a pic of eack pot for ID. I ordered some 15 C pots and got A's from them!
15A = 10% audio taper
15C = 10% reverse log taper
15B = linear taper.
Jim Williams
Audio Upgrades
You could put a meter on the pot to see if it's whacky from damage or factory error. There are also ways to measure taper if you think that is a possibility. What pot/ taper value was it? What did you replace it with?OOps!
well, i though it was all good-passed audio, no noises then i started to adjust the ratio- if i barely turn up the ratio the reduction meter goes full on and i get no audio- until im at the other end of the knob-full CW.
Any one have any thoughts on this?
wrong taper? bad soldering(i did lift some of the pads when de soldering)
un related issues that i forgot this had?
thanks ya’ll!
-SteveMc
