Hi all,
not sure if this is the right place to post this?
So the setup is taking place in an art gallery for an exhibition with sound and video. There are 6 rooms in which exactly the same program is being played and so there is only one source (video file)
Here's the deal.
The program is played with a minimac through HDMI output, then feeds an HDMI active splitter (x8 but only 6 outputs used), then feeds x6 little HDMI over Ethernet/RJ45 converter, then the signal goes to an Ethernet switcher that distributes the signal "in wall" through RJ45 cables to the different rooms (25 meters is the longest length ) in each room there is a pair of powered audio monitors and a projector for the diffusion of the audio and video program. In each room the program is converted back to HDMI using another "cheap" little converter, then that feeds yet another "cheap" little convertor that will covert HDMI to HDMI and extract the audio from that and convert it to analog
To my great surprise, this setup seemed to be working good when i started to do some listening tests yesterday however, as one might imagine i soon realized there where some latency problems.
The latency i am trying to describe here is more about the audio latency that develops between each recievers/rooms rather than the latency between the image and the sound of the video, even if that may also be a concern later on.. (the films are rather short and abstract and the music and sounds that plays along does not have to be perfectly in sync)
The rooms are not totally closed and in fact quite "open" so there is some sound spill all over the gallery. In simple words, the intention here is to fulfill the whole gallery with some sound...
I did not have so much time to do some listening tests yesterday but this is what i discovered. after about 20 minutes of playing i can hear an echo (which should be around 50ms, haas effect) and the only "quick" fix that i found is to unplug the main HDMI cable feeding the splitter and re-plug it hot, this is putting the sound back in phase again. i guess until some latency develops again but i didn't have enough time to test more...
So can one of the experts here tell me where in the chain the latency is happening?
Can someone confirm that this setup is not good and will not work even if we test with less "cheap" converters?
thank you
Here's the deal.
thank you
