Ever since reading this thread nearly a year ago there's been a question in the back of my head that I wanted to address before attempting a build.
What's been bothering me is the loading on the 6C5 as the output tube for the SA-70. From Dougs post above I take it the stock OT is as was likened to the LS-27 meaning a 15Kish pri. If that is the case then you would have the 6C5 running at 2.2ma and a plate resistance of ~19K. Rp is 56K so the 6C5 plate is loaded with ~12K.
Are there any significant problems with loading the 6C5 that far below its plate resistance? I ask this because many of the vintage mike circuits I've seen have the output stages loaded at or slightly above matching condition. The 6J5 (8K) loaded with 100K \\15K on the earlier circuit would seem more like what I'm used to seeing.
I think this question arises out of not being entirely clear on what is most important for the output stage - voltage or current gain. I think it is current though some circuits like the BA-2c have the output tube loaded at 2-4 times rp like a small signal stage.
