spaceludwig
- Joined
- Jul 14, 2011
- Messages
- 186
I have some questions before I start re-capping some channels on an old board. Please be advised that my knowledge of electronics is quite rudimentary so I apologize in advance if anyone is annoyed by my ignorance.
As can be seen in the pictures below:
the three black 47uF caps to the left of the DOA are a good deal bigger then the other 47uF caps (the bigger blue ones) scattered on the board. In This close up
you can clearly see the difference between the black cap on the upper left-hand side and the blue cap to its immediate right. They both have the same value and rating, i.e. 47uF/16 volts.
What I'd like to know is what accounts for the difference in size? I am not the original owner of this board but I know that these have not been changed since they have the same glue at the bottom as the other caps in the console.
I do not want to get involved in some audio-foolery discussion about the merits of using such-and-such cap and how some exotic oil capacitors will change my perception of reality and the other silliness that seems to pervade hi-fi audio blather regarding components. However, Yamaha is a multinational corporation with very deep pockets and know-how, and I am sure when they set out to design these mixing boards that they hired what was regarded as the best-and-brightest electrical engineers of the time that they could get their hands on. I am also assuming that those caps are there because the designers decided it was a good idea. Who am I to argue?
In short, I would appreciate if someone could elucidate me on what the thinking might have been and what I should replace these with if they are not to be general aluminum capacitors, a multitude of which I recently purchased to recap the 2 output and 12 input channels of the console.
Thanks you for your time and consideration.
Cheers!
Cheers!
