earthsled
Hi All!
I'm hoping to revive some interest in this project. A post was started years ago... http://www.groupdiy.com/index.php?topic=13038.0 ...and there's plenty of good info there, but no one seems to be responding anymore. I've uploaded the schematic to the groupdiy docs (the original email seems to have disappeared).
Here's some info I've gathered...
A good option for a high voltage supply seems to be the "practical 300V regulated HT supply" as shown in Morgan Jones' book, Valve Amplifiers... http://www.scribd.com/doc/52148574/62/Specification-of-the-power-supply (page 360 to 362). I'm planning to use MJ's supply for the plates and JLM's AC/DC for the 12.6V heaters plus 48V phantom power. My setup will require two power transformers -- AnTek's AS-05T240 and AS-0515 (respectively) seem to be affordable options.
For audio transformers, there are a few choices from CineMag, Sowter, and possibly others. Right now, I'm leaning towards Cinemag's CMQEE-3440A for the input and the CM-9661A-L for the output. According to David Geren at CineMag, the 3440A will work best with the primary strapped for 150 ohms. Adjusting the secondary load resistance (R26) to 420K will result in an input impedance of around 1.2K. David also mentions that the current production model uses a modified version of the CMMI-7C and that R9 may have been adjusted for increased feedback (reduced gain).
Here's what I need help with...
I'd like to offer a high-impedance input for guitars, basses, etc. My initial thought was to bypass the input transformer and connect the unbalanced signal through a 68K resistor to the grid of V1-A (just like a Fender guitar amp). Will this work?
Also, I'm wondering if the circuit would benefit from a load / termination resistance on the output. Would switching a 620 ohm resistor across pins 2+3 be a good option to have?
Any comments or questions are welcome -- the more the merrier!
