Walt Jung biasing opamps in class A
I agree but it is debatable if an operational amplifier is what you really want for audio. They were originally designed for use in analogue computers for military applications
Well, that is an entirely different debate which has a different set of criteria.
I think you need a lot less bias current than that. The BA283 output stage runs at about 80mA and that is single ended so a push pull class A should require no more than 40mA quiescent but that still equates to nearly 1W of dissipation with a 24V rail.
the BA-440 doesn't have the benefit of transformer loading to increase maximum voltage output and so needs to drive a transformer primary impedance which is one quarter that of the BA-283.
The real reason there are no class A op amps is clearly the quiescent dissipation is way too high
For anything under about a 2K load this is true.
As I have shared numerous times over the years I personally find high impedance differential inputs extremely useful inside large console design for keeping multiple local grounds sorted. Transferring signal between circuit blocks can back reference or forward reference between different grounds (signal 0V) as needed.
I am surely repeating myself but class A delivers limited benefit for obvious reasons.
I'm not sure push-pull works that way (but I am not familiar with BA283). Class AB (push pull?) generally involves a class A current that is a tiny fraction of max output, not 50%.
My tube class A output stage runs at 6mA quiescent and will output +26dBu into a 600 ohm load via a 2:1 step down transformer. The Neve needs a 10dB step up so its quiescent needs to be 16dB higher which would be just under 40mA.
I am not a tube guy..
Even so, the real reason there are no class A op amps is clearly the quiescent dissipation is way too high.
yup...
I am not sure. I am at the wrong PC right now. I will check later.
ian
I read a comment referencing Walt Jung and how he had an article about biasing opamps( example 5532) to be class A operation.
That all you had to do was add a resistor to the opamp output going to the negative rail.
Does anyone have any details on this or the article the reference in the comment?
I would be curious as to what it achieves outside of heat increase?
I personally don't think you need to do anything for the op amp output to run class A. Especially if it has a bipolar PSU. The cross over from positive to negative is controlled by the op amp internal components. It is after all the same basic output configuration as a fully complementary transistor power amplifier.
FYI, the B183/283 amplifiers are pure class A, a 2N3055 pulling against a 47Ω resistor. The output stage also has gain. One other technique for lessening the op-amp crossover glitch is to offset the power rails in order to move the disconnected area away from the lowest level program to where it's less apparent. The only approach I can think of is to have the output transistor, connected to the positive rail, act as a constant current source when not passing its portion of the audio signal. In other words, never turning completely off. I'm about to see what I can do with the new CMOS op-amps, OPA991 and 992, rail to rail output up to ±20 volts. The output can be turned off and go high impedance so outputs can all be wired together for use as a multi position, high level, switch. Also internal RF Rejection.
These were basically Class B (or AB for da pedantic) though I supposed if you used B210 (running 10mA total) with a 10k load, you could claim it was operating Class A :)
Yes exactly.
Except, as designed, the B210 drives a 600 ohm load so, class AB 🙂
A class A push pull stage operating at 10mA quiescent can sink or source up to 20mA peak or 14mA rms without ever leaving class A operation . Into a 600 ohm load, 14mA rms is +20dBu.
Thanks for posting the schematic Ian; It saves having to look at the boards I have and work it out (again). I also have the updated mini boards that used a NE5534A op amp used on the later produced desks such as Broadcasting House (the studio that formed Radio 4 material IIRC.
YES you CAN run a 5534 at plus and minus 24 Volts which I discovered when revisiting the studio a year after it was commissioned and discovered the 5v6 Zener 'droppers' had been forgotten on the motherboard. OOPS!
Back in 1974 I was a 23 year old recent graduate who got his dream job designing mixers at Neve. For many years I had been an avid reader of Tape Recoder magazine which morphed into the pro audio focused Studio Sound so I knew the names of most of the mixer manufacturers in the UK but I had never come across Calrec. It was not until one of our salesman took me to BBC Television Centre that I saw my first Calrec mixer. It looked very much like a Neve, even the paint was almost identical. The knobs were different but the EQ was much the same as were the routing modules. But, of course, they would be because that is when I realised the BBC wrote the spec (in detail) and sent it out to tender. But I still thought it strange that Calrec did not seem to advertise itself.
:mad:
+/- 24V exceeds the published max voltage spec (+/- 22V). I hope you added the missing zeners.
Puh..lease Ian!! I don't go damning N**e sh*t with faint praise .. or at least most of the time :)
Calrec never advertised cos their order books were always full from the Broadcast organisations ... and after Abba bought the first M series for their Stockholm studios, from selected 'music' customers too.
That B 210 module was designed for an EVIL purpose dear to John Robert's heart. It could destroy any input stage in its time ... including the obligatory release of Holy Smoke from the victim. :eek:
I'm not sure creaming input stages was dear to my heart, BUT it reminds me of a story... The lads in our service department would often call upon me for help with unusual problems. Peavey sold a couple decent vacuum tube studio SKUs under the AMR brand. One a nice vacuum tube mic preamp (the VMP2) was pretty popular with Mackie 8bus console customers. The problem for them was that the VMP's hot output creamed the 8bus' inputs. I provided the lads in Peavey service with a simple passive (resistive) pad to knock off about 10 dB of level, so the Mackie 8bus customers could use their Peavey (AMR) mic preamps, without overloading their console inputs.
LOL
Calrec was founded in 1964 to make microphones - and very good ones they were too. At that time, there were only two broadcasting organisations in the UK - the BBC and ITV. And that remained the case until just after I joined Neve in 1974 when commercial radio began in the UK.
I have BBC Calrec J series PQ10-42 Schematics that Calrec kindly gave me when ! had 16 channels. I'd post them up if anyone wants to see them. They sound amazing. I personally prefer them to the Neve 1073. They have a lighter mid range and you can turn the eq any direction and it still sounds cool, as does the crunch of the saturation.
Matt did a great IAA 500 version that were all SMT but sounded 99% there. They just had a couple of layout problems with switching but he nailed the sound to my ears. He was too busy to continue and I had studio projects to finish but it would be an excellent DIY or AML project if it was more hands on.
Calrec Neve and Audix mixers had a common 'theme' for a time because all 3 companies were making desks for the BBC who 'published' a design (mechanical layout really) for various modules that would form channel strips and other random stuff like telephone interface units so that a SOUND Engineer could walk into any studio and work immediately without having to learn wgere all the controls were. the 3 companies could implement the electronics as they felt fit with Audix and NEVE plumping for 24 Volt DC rail and Calrec plus and minus 24 Volts. These were the 'GP' desks and the facilities offered suited live radio, TV (I think) and production desks for recorded programming. The frequencies used for EQ and filtering , cut boost etc were defined by the BBC and as inductors were the standard way to get bell response all were pretty similar. I worked on (test and commissioning) GP desks at Audix and then Calrec.
Plenty of power amps with x-over distortion. Has anyone on this thread actually tried it and measured the results or is this all speculation and personal bias?The question for me would be how do they perform open loop or very low nfb where x-over would be obvious with and without the bias resistors.
Yes Please to uploading the schematics to the Technical Documents area.
