Highest voltage, low-noise FET
Help Support GroupDIY:
MaxDM
I’ve been wanting to experiment with a FET with a 150v to 200v B+ In a condenser mic
I read something a long time ago on Facebook regarding one, which I looked up, and it seemed to be worth trying.
I wrote the part number down but seem to have misplaced it.
Can anyone tell me what currently manufactured FET can be used in such an application?
analag
Mars
That looks promising!
I wonder if it's linear enough to use as you would a triode.
If you care to experiment, you could do a grounded source in a source follower into say a 4:1 output transformer. That would leave you with enough gain to apply a small amount of feedback to linearize things a bit.
mhelin
Tampere, Finland
Winston OBoogie
UK.
I know that the LND150's work well as low current, high voltage current sources, but no experience with them other than that.
Might be worth a shot.
My gut is that I'd probably opt for a cascoded 2SK/LSK170 but, lots of ways we can skin cats.
Matt Nolan
Bath, England, UK
I'm out of practice with this stuff. What's the Miller capacitance of the LND150 going to be in a typical triode-alike circuit, compared with the capsule capacitance?
MisterCMRR
Active member
Ventura, CA
Miller C occurs only when the drain has an inverted version of the signal at the gate - so it doesn't apply to followers, for example. Miller effect will multiply the Crss (drain-to-gate) C by the actual in-circuit voltage gain. So, if you use it "grounded source" (it's what the last s in Crss signifies, BTW), and choose a drain load resistor that gives the stage a gain of 10, then the input capacitance seen at the gate will appear to be 10 times the Crss figure. This is in addition to the normal Ciss (gate-to-drain) capacitance. So, in the gain of 10 circuit, the input capacitance would be (10 x 0.5 pF) + 7.5 pF = 17.5 pF ... using the "typical" numbers from the data sheet.
Of course, stage gain is transconductance (Gfs) x R load - in this case 2.0 milli-mhos x 5 kΩ = 10 ... and 50 kΩ would give a gain of 100, etc. ... again using the typical Gfs figure from the data sheet.
