Homebrew thermal epoxy MacGyver(w/pics)
Freq Band
GDIY Supporter
Electra City
I have had no luck finding "thermal glue" for attatching heatsinks to IC chips that need it.
So I MacGyver'd my own.... (and no, I wasn't trapped in an abandonded mountain cabin with bad guys chasing me, in order to save a beautiful girl from a politically incorrect injustice).
The metal powder is from a craft store, or well stocked paint store.
It is powdered aluminum. I chose clear type epoxy because coloured type has pigment, and possibly other fillers : I wanted the ratio of epoxy-to-metal(powder) to be high....maximum stick/maximum metal.
I seem to come up with an eyeballed mix ratio of:
equal parts glue, and powder
(where glue includes part A & B together)
....this simply means a lump of glue is the same size as a lump of the powder.
I was curious to see if I could put "too much" metal in the glue, and have it pass 24v @1 amp....but I tried it, and it did not pass anything. Nor would it read as any resistance/continuity on my Fluke DMM.
IMPORTANT :!: YUCKY DUST HAZARD:
Always mix/handle this aluminum powder outside, or a non-windy place......it loves to get airborne and I doubt it's good for you. I mix it in my dirty garage with a dust mask, then run inside and use it :grin:
(If I am correct, the longer 'working time' the epoxy has, the less brittle it is, or will become, over time. Any thoughts?)
EXAMPLES:
(this is where I'm glueing two AD811 single opamps, to make them fit as a dual 8pin type ....I didn't have the correct dual chip (AD812) :roll: ))
http://i5.photobucket.com/albums/y177/Midiot/dscn1884.jpg
http://i5.photobucket.com/albums/y177/Midiot/DSCN1886.jpg
http://i5.photobucket.com/albums/y177/Midiot/DSCN1891.jpg
http://i5.photobucket.com/albums/y177/Midiot/DSCN1890.jpg
(EDIT...oops these are pics of before I came up with the metal mixture, so just pretend the glue you see is aluminum coloured, not black :wink: )
=FB=
Look for Arcticsilver thermal adhesive or other brands like it. The places that PC overclockers buy parts should have it.
nice idea,
did you try to check how good is the thermal conductivity of the glue in someway?
When I worked with resins, we used to make our own thermal goop for casting heated moulds in a very similar way.... just mix aluminum granules and epoxy... :thumb: Araldite was famous for having a low temperature tolerance.....softening around 70 deg Centigrade....and you want to make sure the "metal" powder is genuine metal, not some sexy looking craft powder.... :green:
that clear epoxy does not seem best to me...ive had experiences where it turns rubbery and flexible with time...try "jb weld" it is the most durable epoxy I have ever used, and may have some metal content built in...on that point, J.H. mensions he uses a silicone filler in his opamps so as not to mechanically stress components that expand and contract with thermal cycles.
