Purusha
Hi Brian, I just checked your monitor controller picture and it looks like something I want to build for my studio but without any meters. Do you have some nice schematics which you could share?
Brian Roth said:I built this unit for my friend/client Dave Gardner, who operates Magneto Mastering in Minneapolis:
http://www.brianroth.com/projects/gardner/monitor-control.jpg
The primary signal path is totally passive. The "input" switch is a 12 pole Electroswitch. Each of the three stereo inputs requires two poles per channel. , hence the need for 12 poles. Any unused input is terminated into 1200 Ohms since the entire system was designed as a 1200 Ohm load fior the sources. The Shallco stepped attenuator is also a custom 1200 Ohm unit.
The "output" switch is also an Electroswitch 12 pole part. Each output tip/ring pair requires two switch poles per channel since any unused "destination" is shorted to avoid crosstalk.
Active circuity is required for the "mono" listening mode as well as for the meter buffers.
If I did this sort of gizmo again, I would be tempted to use relays.
Bri
