Axelerator
Hi, in my other actual thread i described my problem with my neve pultec clone.
I diyd myself an audio probe with a shielded chinch cable, tip via 0.68uf to signal plus, shield to ground of my old receiver , where i want to use the cd input.
As this is not working, i assume i would have to connect the shield to both grounds( test cuircuit audio ground ) and chinch outer ring of my receiver ?
> what would lead to some humm but i should hear my test signal ?
or has the cd input a too high input impedance for this test ? maybe the filter formed by the cap and the input impedance cuts to much low and mid content , so i can hear nothing ?
thanks again..
i did ask in a new thread because i think this could be informative for all the other people want to test cicuits with an diy audio probe..
thanks again..
