stereokillah
YESalso, this is the only switch/pot in the unit which needs to be 2 decks, right?
Sorry don't have link but i think you may find it on ebay
The opamp stage, connected to this point will hate you just for the idea of frying its input stage.do I need to make a bridge with the hole on the other end
Yes, but you already have placed this 47k on the SSC board. Nothing to add or to change in this spot.Alessio said:It seems like a need a resistor before the turbo board???
Double check ALL resistor values for same resistance L+R channel, beginning at GSSL input thru the SSC boards, thru Turbo board and back to GSSL board. Might be easier to measure at the corresponding opamp output pins where levels drift apart when GSSL input L+R is fed with same signal.On both channel then, when the threshold is at 0 (so it should not compress) and I switch the compression on I still compress 1dB on the right channel and 2.8dB on the left channel (where the turbo is connected). If I move the threshold down (so I'm compressing) the difference between the 2 channels increase as well...
Does this have something to do with the 2x20k resistors at the inputs of the 2 SSC? Because now I solder only 1 10k because I use only 1 input (the L input) on both SSC...
I'd like to have this unit perfectly calibrated I can use trimmer resistors I just dont know where :![]()
Well spotted, this just might be it. Have a 2nd look at the TurboInstallationManual.pdf, page 6.stereokillah said:check the signal between your controle board ratio and your turbo ratio under the board i think you have a bad way in your ratio connetion with turbo
