> Is there a way to take 48v dc (for phantom) from a regulated 24 power supply?
A way? Yes.
An easy? Maybe not.
Oh, an easy way is to use three 9V batteries or a 24V wall-wart, and stack it up on top of the 24V to get 48V.
Of course if you hunt a little more, you can find surplus 48V wall-warts. (The older H-P DeskJet printers used a 48V power pack that outlives the printers.)
Really the next step is to just get a 48V power transformer, rectify and regulate it.
If you -only- have 24V DC, as in field recording: there are ways to convert anything to anything, but not easy. For example, if you are running on car batteries, get a 12VDC-120VAC inverter, and a 120VAC-48VDC power pack. That will work, but the typical phantom supply is much lower power than most inverters, so it will be very inefficent. That three-9V-battery plan is probably a wiser idea.
For general DC step-up, use a transistor and a choke across your DC supply. Switch the transistor on and off pretty fast (if you leave it on too long, the choke or battery burns up). The choke will kick to a high DC voltage, up to maybe 10 times higher with iron-core chokes. Rectify and filter that, and then feedback the output voltage to the transistor controller to cleverly adjust the on/off times and get the desired output voltage. The formulas are said to be simple, but it isn't my thing.
Since you want just 1:2 step-up, the switched capacitor voltage double comes to mind. Get an audio power amplifier chip. Use feedback to make it self-oscillate. Preferably outside the audio band, but not much higher because audio chips aren't made to do that. You get a 23V peak to peak square wave. Two diodes and two caps can voltage-double that to about 45V at light load. It naturally output just double the supply voltage, minus losses, a few volts for a good speaker-amp chip and Phantom sized loading.
Remember that many many "48V" phantom microphones are perfectly happy with 24V.
