How to distinguish tubes?
rich
I've got a box of 12Ax7 tubes and 12Au7 tubes all mixed with the lettering rubbed off. Is there any way to visually distinguish the tubes?
No. While AU and AX from the same factory may look a little different, if you have a mixed lot from several factories you can't do it.
Set up a socket with heater power, grid strapped to cathode, and 48V on the plate. Measure plate-cathode current. AU will read much higher than AX.
[quote author="PRR"]
Set up a socket with heater power, grid strapped to cathode, and 48V on the plate. Measure plate-cathode current. AU will read much higher than AX.[/quote]
Sorry for my naivety but does strap the grid to cathode mean connect the grid pin directly to the cathode pin?
[quote author="PRR"]No. While AU and AX from the same factory may look a little different, if you have a mixed lot from several factories you can't do it.
Getting ready to go through these tubes and wanted to make sure I undestand this correctly.
Am I only hookin up 1/2 the tube? So I've got 12 volts dc to pins 4 and 5 right? connect or strap pin 2 and 3 together? and pin three goes to ground?
Then I measure current with my meter between pin2 and 48 volts?
[quote author="rafafredd"]Note that the meter should go in series.[/quote]
I've got the positive lead of the meter directly on the 48V and the negative lead on pin 1, correct?
