berkleystudios
any current projects out there i can make use of for a pair of
Jensen JT-123-SL line out transformers
http://www.jensen-transformers.com/datashts/123slcf.pdf
and Jensen JT-11P-1 line in trasnformers
http://www.jensen-transformers.com/datashts/11p1.pdf
was thinking maybe a stereo pair of g pultecs?
im pretty sure that the input trannys would work but would the out put be able to be rewired 2:1 instead of 1:1?
https://pcbgrinder.com/download/Gyraf_PEQ1A_Schematic.gif
or could the output be used to replace a ea 2508? with it in 1:3 it has a 600 ohm impedance when the jensen has a 600 ohm impedace at 1:1....
