radiance
Well, well well, what have we here. Ten meters Frank. You must be in meassuring heaven.
Quick and dirty: Use a signal generator and sweep it with a set amount of output!And unless the drop-off is gross, if this is your only meter, how do you know?
Nope, maybe "Nirvana"...this is measuring "Heaven"!You must be in meassuring heaven.
Have you tried cleaning the time base switch with DeOxit? I have a 100MHz Tek at work that suddenly went wonky and it took a couple of switch cleanings to get it straightened out.my 100MHz tek digital just has some sort of weird problem that I have no idea how to fix![]()
