Spencerleehorton
its definetly a step down transformer right? 6:1 should be the right ratio i thought!!
as in mic side pri should be 6 and to socket should be 1.
right. Original BV08 is 6.5 to 1. EF80(0) will work with 7:1 or more, too.its definetly a step down transformer right? 6:1 should be the right ratio i thought!!
Very good, you are always very creative with your mistakes!well the helarious mistake this time was i'd put in a 47mH inductor in place of a 1G resistor! looked pretty much the same!!!
all works perfectly now!! doh!!
Basically yes, but a small resistor at this point would still form a nice RC filter with the following large capacitor. With a 1R resistor, approx. 0.3V would be converted into heat, the LM317 would still have sufficient voltage to regulate and would become less warm. Win - win.10v at input so as there is no noise i think im good?
Yes, the BV.08 is definitely a microphone output step down transformer with 6.5:1 ratio.Its definetly a step down transformer right? 6:1 should be the right ratio i thought!!
Perfect! Do you hear a difference in noise when you change the heater voltage? (6.3V vs. 5V). I would be interested to know how you see this.I put in 3 x 5R in paralell to get 1.6R in replacement of the 20R, all sounds good, it was pretty quiet anyways but probably even quiter now.
