That is not really a mic pre amp, that is just a common emitter amplifier with a Sziklai transistor arrangement, if you really want a mic pre you should start by having a differential input.View attachment 109956
This is what i tinkered with. I tried making a test pcb, but it didn´t work. I wonder why that is.
If anyone has a thought please share.
Br Hans
Actually it seems to work in simulation.
That is better, I still think the 10k resistor is not needed. It is bootstrapped, which means that practically no current flows through it, bootstrapping is useful when you want to raise the input impedance, but not in that manner. The 22uF cap is too small, raise it to 100uF at least. The 6.8pF cap might not be needed, an engineering premise is not to add something which is not required. The Falstad simulator is very lame to model things like parasitic oscillations, build the thing in a protoboard and, if you notice oscillations, then you can think about adding that cap, otherwise, don't. Something important to keep in mind is that the 6.8pF cap experiences the Miller effect, with the gain you have, it presents an effective capacitance value of 172 pF, which is still ok, but, again, might be completely unnecessary. In your first circuit, since it had more gain, the cap had an effective value of around 3.3 nF due to Miller effect, which forms a pole with the 1.7k resistor at roughly 28 kHz, which is unpleasantly low, producing 1.8dB of attenuation at 20 kHz, 1.1dB at 15kHz, and 0.5dB at 10kHz; not good.I had already started fiddling but i will keep that in mind. I tried again and upped the voltage of the input to what i believe are the voltages of a SM57 trough a step up transformer.
Thank you for taking time and explaining. Learning a lot, and stuff that i need to learn more about. I will tinker some more.That is better, I still think the 10k resistor is not needed. It is bootstrapped, which means that practically no current flows through it, bootstrapping is useful when you want to raise the input impedance, but not in that manner. The 22uF cap is too small, raise it to 100uF at least. The 6.8pF cap might not be needed, an engineering premise is not to add something which is not required. The Falstad simulator is very lame to model things like parasitic oscillations, build the thing in a protoboard and, if you notice oscillations, then you can think about adding that cap, otherwise, don't. Something important to keep in mind is that the 6.8pF cap experiences the Miller effect, with the gain you have, it presents an effective capacitance value of 172 pF, which is still ok, but, again, might be completely unnecessary. In your first circuit, since it had more gain, the cap had an effective value of around 3.3 nF due to Miller effect, which forms a pole with the 1.7k resistor at roughly 28 kHz, which is unpleasantly low, producing 1.8dB of attenuation at 20 kHz, 1.1dB at 15kHz, and 0.5dB at 10kHz; not good.
The 220 ohm resistor in parallel should give you better linearity, since it represents a degeneration factor of around 15, but it lowered your gain to 32 dB (not counting the 10K load), with the 10 K load the gain is 28dB, which is far from the maximum standard 60 dB gain of a typical preamp.
Newmarket is completely right, the Falstad simulator is educational; not really meant to be used as a tool to check designs before you make a PCB.
The best Sims I've used, and still use (thanks to the University) are Keysight ADS and Keysight Genesys, particularly the former is in a whole different league, both in terms of price, power and accuracy. However, you know that any Sim is as only as good as its models. I believe I heard that you can load SPICE models into Falstad, but I am not entirely sure about this. I've know the Falstad sim since like 2008, and it has somehow progressed from being simply a cute Java applet, to being a more complex Java applet; but it is still a Java applet. Whenever someone shows me his/her circuits in Falstad, I know they are beginners.Well, I wasn't meaning to be critical. But I've only heard of the Falstaf sim on this site. Maybe as I'm not in education. Professionally anyone I know uses some permutation of Simetrix/Simplis (paid for) ; LT Spice; TINA (mainly free TI version); TI Web Bench etc. ; ECAD integrated SIM eg Altium / MultiSim.
Falstaf always seems to be problematic in transferring to physical circuits ? Happy to be contradicted. No vested interest.
A sim that I used to use back in my college days for digital stuff is Proteus, I no longer see many people still using it though.
I've heard a lot fo good stuff about Micro Cap, but with all the free sims available by big companies like TINA or LTSpice, I think it hasn't got much attention. However, there is a free simulator that is at a whole different level called Qucs-S. You should also download Xyce with it, since they work together. Qucs-S is a SPICE simulator but it goes beyond SPICE, it can do S parameters and Harmonic Balance analysis. You can couple it with Octave for co-simulation. I just started using it and I was blown away. It is like the free version of Genesys or something similar, minus the EM simulation.To the OP (and everybody elese) I would recommend Micro CAP for circuit simulation/analysis. It's been available 100% free for some years now (unsupported thought) but it's a professional tool and not so hard to start running for the basic stuff.
Even simpler is a 1510/217/163 with a simple op amp output; how often do you reallly need a mic pre to have a balanced output? Unbalanced line levels with modern equipment and modern cables are quite noise-resistant.
I've routinely run them 75' and more with no noise at all.
I must say that quite a lot of times I just prefer the "quasi-balanced" option of adding one resistor in series with the output for stability and an identical one from the cold terminal to ground.tbh no good reason to not have an impedance balanced or ground sensing output. Still just one opamp stage. No point introducing an unbalanced interface when your in control imo
I've always been fascinated by this method used by Soundcraft; anyone seen it used anwhere else?I must say that quite a lot of times I just prefer the "quasi-balanced" option of adding one resistor in series with the output for stability and an identical one from the cold terminal to ground.
Seems to be some sort of ground sensing circuit. Perhaps it is mentioned in Douglas Self's book, since he used to work at Soundcraft.I've always been fascinated by this method used by Soundcraft; anyone seen it used anwhere else?
Not to quibble about terminology but that topology is called "impedance balanced". Some remarkable bang for the buck when a couple cents worth of resistors allow the marketers to call the output "balanced" . Not only that it works.I must say that quite a lot of times I just prefer the "quasi-balanced" option of adding one resistor in series with the output for stability and an identical one from the cold terminal to ground.
Impedance balanced with a simple differential output where the signal is referenced to the external ground. This (differential) is widely done for unbalanced insert points. The impedance balanced outputs are widely used on value products (because it's cheap).I've always been fascinated by this method used by Soundcraft; anyone seen it used anwhere else?
Yes, however, if being completely anal, impedance balanced is whatever topology that has both impedances balanced with respect to ground.Not to quibble about terminology but that topology is called "impedance balanced". Some remarkable bang for the buck when a couple cents worth of resistors allow the marketers to call the output "balanced" . Not only that it works.
In my experience in the mixer business (decades ago) "impedance balanced" was the terminology used to describe that very specific topology where you add one equal value resistor in series with the - output lead connected to ground to convert an unbalanced output to (cough) balanced.Yes, however, if being completely anal. impedance balanced is whatever topology that has both impedances balanced with respect to ground.
Edit: the idea was to use this instead of the 4559 mic pre in tascam mod 3. It has a tamura input tx. I have substituted it with a resistor.
