Dubka
where are you buying cases with no front panel?!
warpie said:does anyone else has problems with the back panel of slim line by modushop?
It bends!!! :
Hank Dussen said:They come with a aluminum front panel but you can use this for your prototype.
The only problem with using these panels is that I think they're a little rough. (at least much rougher then Franks engraved panels)Kingston said:I have always had my proper front panels cut/drilled/engraved from these modushop 4mm aluminum templates. I just send them to the CNC guy with a CAD image of the final product, and out comes a finished panel.
andre tchmil said:Does anyone knows why the back panel of the "pesante" line can't be drilled ?
http://www.modushop.biz/ecommerce/cat071_l2.php?n=1
baadc0de said:I have many 2U and 3U pesante cases and some I have drilled with a stepped drill, the others have been cnc'd with laser. both work well
Hank Dussen said:Everything but the front is steel. It's a little bit harder but of course can be drilled.
They're probably just saying THEY won't drill or engrave the back because it doesn't fit their CNC machine.
Hank Dussen said:Check out http://www.modushop.biz
I've also seen these cases in some other shops, so you might find them somewhere in the UK as well. (Forgotten where tough)
letterbeacon said:Does anyone know where I can buy a fairly shallow 2U rack enclosure? I was going to buy the Modushop slimline 170mm enclosure, but it appears from replies earlier in the thread, that the back panel is fairly thin.
