I was able to measure an unclipped 100V peak-to-peak signal at my tube mixer output (measured directly at the XLR/transformer secondary). 33 dBu. Not bad...
JohnRoberts said:I guess you can always pad this down to feed an A/D converter.
I'm not a tube guy but back when I was designing (solid state) mixers there was a constant tension between headroom and signal to noise... If there is 100Vp-p output what is the noise floor below that? Or more importantly where is the noise floor below nominal 0VU.ruffrecords said:JohnRoberts said:I guess you can always pad this down to feed an A/D converter.
This is what it is capable of, not what it normally outputs. It just means it has a lot of headroom above a nominal +4dBu.
12afael said:Rock n' roll!! or even better HEAVY METAL!
I bet Manowar or ACDC would apreciate that headroom hehe
What does headroom sound like? Clean?
12afael said:What does headroom sound like? Clean?
LOUD!
pucho812 said:what tube mixer is it?
JohnRoberts said:I'm not a tube guy but back when I was designing (solid state) mixers there was a constant tension between headroom and signal to noise... If there is 100Vp-p output what is the noise floor below that? Or more importantly where is the noise floor below nominal 0VU.ruffrecords said:JohnRoberts said:I guess you can always pad this down to feed an A/D converter.
Since 100Vp-p is roughly +33dBu that makes a respectable 113 dB dynamic range (18+ bits). A pad on the output down to more conventional operating signal level would reduce the signal and the noise so that dynamic range is preserved. (of course that ASSumes the -80dBu and +33dBu exist at the same time.).ruffrecords said:Depends on the gain but it can be below -80dBu.
