ok we checked the resistor method against the v/i method at a set of low freqs, here is what we found:
resistor method - v/i method
10 hz - 91.0 H----88.6 H
15 hz - 88.2 H---86.6 H
20 hz - 83.5 H---84.7 zh
30 hz - 81.0 H---81.4 H
40 hz - 78.0 H---77.9 H
matches up pretty darn good, any error is probably non exact resistor-voltage nulling as it can be a tedious process, so probably no need to use smaller resistors and compensate for Z angle,
experiment over-back to the 217 xfmr
