pucho812
nice prices compared to elsewhere
https://lovemyswitches.com/categories/switches/toggle-switches/mini-toggle-switches.html
;DWe ship INTERNATIONALLY every day from green and caffeinated Portland, OR USA.
Beware that these are rated at 250Vac 2A/125Vac 5A.pucho812 said:nice prices compared to elsewhere
abbey road d enfer said:Beware that these are rated at 250Vac 2A/125Vac 5A.
You cannot compare with low-level types (gold-flash contacts).
Does that really make a difference? Gold plated contact toggles are like $20 USD. I never thought I needed to dig that deep. When would I want to use gold plated?abbey road d enfer said:Beware that these are rated at 250Vac 2A/125Vac 5A.
Gold plated contacts are probably better for dry (no/low current) switching.squarewave said:Does that really make a difference? Gold plated contact toggles are like $20 USD. I never thought I needed to dig that deep. When would I want to use gold plated?
Toggles are a part that you probably don't want to get cheap with though. Cheap ones can have a wonky feel. The bat will move a lot. And if you apply too much heat they can break entirely to the point where the switching contacts don't mate properly.
Personally I like NKK toggles. They seem a little more sturdy than most types. That is reflected in the price but the regular silver plated ones are $5-$10 USD depending conconfiguration. And they have a LOT of configuations. They have some pretty cool configurations like a large M12 busing with a large bat but the body is a regular mini toggle.
abbey road d enfer said:I use these
https://fr.rs-online.com/web/p/interrupteurs-a-levier/7109713/
They don't break the bank.
That part is apparently considered obsolete and the derivatives that are not are not stocked. At least the ones with the Alco code G for gold contacts is not found anywhere.abbey road d enfer said:I use these
I don't know, I just have a stash of them.squarewave said:That part is apparently considered obsolete and the derivatives that are not are not stocked. At least the ones with the Alco code G for gold contacts is not found anywhere.
Exactly. Ag contacts do oxydize. It's the spark that clean them.But I am curious about using gold contacts now. Not sure I understand JR about dry / no current. Meaning low power AC only?
Mainly inconsistant contact. You may have to toggle the switch a couple of times before getting a positive contact.rp said:How would the difference between gold and not-gold contact switches manifest? Distortion? Resistance? Intermittent contact over time? Other?
Not a widespread problem but symptoms can vary with fault mechanism.rp said:How would the difference between gold and not-gold contact switches manifest? Distortion? Resistance? Intermittent contact over time? Other?
