mhelin
Do you mean that when you set the FSYNC_OFFSET to zero in xcore app it does't honor that setting? There is no LRCK in TDM, just the FSYNC. You can combine somehow I2S and TDM if you need to use both at the same time but I guess you have to use left justified PCM mode instead of I2S then with the zero-offset TDM, or I2S with one-clock-offset TDM.
