mhelin said:XMOS USB audio stack already contains digital mixer which can be controlled from host via USB.
https://www.xmos.com/developer/published/usb-audio-software-design-guide
See Ch. 3.6 Digital Mixer page 30
Problem is there is no proper application for control, only some command line application:
"The mixer can be controlled from a host PC by sending requests to Endpoint 0.
XMOS provides a simple command line based sample application demonstrating
how the mixer can be controlled."
However, the API makes it possible to route inputs directly to wanted outputs so you can make multiple monitor mixes for an example quite easily.
rkn80 said:becario, did it work with the FT232?
