The 13A plug is only in former colonies that stuck to Blighty standards .. eg Singapore & HK.PRR said:In 230V lands the everyday plug is good for 13A or 16A.
In 115V lands we need more current and 20A connectors are widely used.
So there is probably a Euro-Spec for testing 16A connectors, and a USA spec for testing 20A connectors.
ricardo said:I'm not sure the Rebel Colonial (US) plug would be considered 20A by British Standards.
PRR said:The vast majority of US outlets and plugs are 15A.
There is a similar-but-different 20A design. I know because I have cut these off and installed 15A plugs when the load isn't really 20A, or if I will not be around when the fire starts.
While we maybe should use 15A circuit fuses for general things, you don't see anything but 20A circuits anymore. And duplex 15A outlets may (or may not!) be rated 20A pass-through.
Since the Neutrik is probably much better built than the 2-prong plug, it is reasonable they would test to the 20A standard.
BTW: while the screw-lamp can be ascribed to Edison, I do not think the 2-prong plug can. Plugs and outlets came much later than lamp sockets and there were multiple designs. It is not clear that the "standard" plug has any authority.
The politics these days is not worthy of debate... My local senate primary did not get 50% so there will be a run-off... I am insulted by the lowest common denominator nature of political arguments down here, but I've come to expect that living in MS.Kingston said:I read the topic too quickly as "Is the current USA any different?" and expected a political debate.
