Cqwet Dbdfte
- Joined
- Oct 2, 2023
- Messages
- 431
This aluminum tape didn’t improve it at all…and it definitely has electrical contact with the mic body (tested it with a DMM):
If RF enters thru the top screen, shielding elsewhere wont help. Put the foil over the "screen" area, at least to locate the RF entry point.
Those slots at the screen have a length for some perfect 1/4 wave RF frequency, working as slot antennae .
The metal screen(s) behind the slots should have very good metallic contact to the body, and no glue, paint, or insulators between metal parts. If the capsule fine mesh screen does not have good metallic connection to the mike body, and/or the threads do not provide for an RF tight interconnection (with very short gaps) a floating metal part may work as an antenna.
Some (woven) metal screens have poor interconnections, or may develop it over time. Screen rooms for RF testing are notably worse for screen material, solid sheet-metal is preferred. That not to say wire-screen material could not be made better. Expanded material would be better for shielding.
I cannot find any pic on how the screens in the mike are bonded together.
