Cqwet Dbdfte
- Joined
- Oct 2, 2023
- Messages
- 431
Current, very low.
Freq?
Impedance? Higher is better, 2k is possible
Freq?
Not sure how much band n71 is rolled out. Uplink 663 - 698MHz.5G cellular starts at 618MHz in North America.
I'm using the PCB created by Graeme Woller. Attached is the schematic.Can you post your EXACT DIY circuit?
From XLR P1, there's currently a solid wire that goes to the XLR screw terminal tab. from there, it connects with another solid wire to the circuit board's XLR1 pad. Here's how that looks:Show ALL the connections between the PCB and the mike body and try to get them in the approximate physical positions on the circuit. Also the wiring of the XLR in the mike. What route does XLR p1 take before it gets to the mike body ?
Micparts doesn't provide the schematic, but it's nearly identical except they use 22uF electrolytic caps and a 0.022uF ceramic bypass cap across the electrolytic cap for the JFET's source to ground.Then can you do the same for the MP item?
The only thing I could think of is my cast iron dutch oven. I've got the mic in there and it's still going nuts with my cell phone nearby almost as much as before.Put the mike inside a metal bag or metal can, and see if RF get thru the cable.
A cookie tin may work.
Being the interference is a 100Hz harmonic series dont exclude Power supply issues.
The cable was in a notch. I don't really have anything else that'd work....ehh
Not a airtight test.
The metal should have no openings.
The opening for the cable should be snug, not shure how tight a metalized chips bag would be
I'll have to try tomorrow. Maybe I can tie it onto the ground rod that's grounding my ham shack.Is there some way you could conveniently earth the container?
I don't understand this pic. Is this the back of the XLR pins on the mike? Can you label p1 p2 p3 & the 'screw terminal tab'? What is the Grey conical bit at the top of the pic?From XLR P1, there's currently a solid wire that goes to the XLR screw terminal tab. from there, it connects with another solid wire to the circuit board's XLR1 pad. Here's how that looks:
Ground at 700MHz+ would require a low inductance conductor, think as wide as it is long. Getting a low contact resistant connection to Terra firma use a couple of square yards of copper plate.I'll have to try tomorrow. Maybe I can tie it onto the ground rod that's grounding my ham shack.
