llTheSystemll
New member
- Joined
- Nov 18, 2011
- Messages
- 4
synthiaks said:I think the question is:
Are there any Parts in the Orban that is Dipped in Epoxy and therefore unrepairable?
Its hard to tell from the picture. But those black things sure looks like epoxy. The part number on them seem to be the same so they must be the same part. Maybe an OP amp. But without schematic its hard to tell.
When you look carefully at your picture, what do you see: eight little daughter boards or eight black modules ?llTheSystemll said:"IF the unit you have is NOT full of epoxy potted modules, you will see eight little daughter boards. ....
I think you can always replace the eight black modules with eight little - self-made - daughterboards to influence your luck.llTheSystemll said:.... If it IS full of epoxy potted modules, proceed to the last step. If you see the daughter cards exposed, however, you are in luck."
Based on this and the fact that daughter cards are not visible I am going to assume that this one is potted and not repairable or cannot be modded.
