What does a ground loop means in a pedal board? Where there is no connection to earth.
More likely ground contamination, than a magnetic winding loop, but many guitar players using multiple pedals experience ground related noise problems.
In principle the only solid safety ground bond should be via the guitar amp chassis. I am not versed in guitar amp input jack practices but suspect the input jack on many is chassis grounded.
Sundry wall-wart powered pedals strung together with who know what power supply designs. Most are probably 2 wire (so double insulated) but who knows what they might be dumping into signal ground?
For today's TMI (veer) a couple years ago I did some research into an idea I was pursuing combining a cap coupled ground lift with a GFCI protected line cord. My design thesis was to cap couple the ground through a decent sized cap (I don't recall my actual value but probably a 0.1uF or so of the safety caps designed to fail short circuit). My concept was to prevent the hard ground bond at 60/120Hz, while still protecting human safety. I sent my prototype to James Brown to test on his personal rig. At the time James was selling his own guitar pedals, now he is working at Fender. He tested my prototype on his personal rig, with multiple pedals and it was silent.
Many guitar players get shocked either by external mains voltage sources (like from hot chassis mixers via the microphone) or from guitar amps with energized chassis. I sized my cap coupled safety ground to deliver sub lethal current to typical mains voltage exposure. The icing on the cake of my guitar player safety device, was to also sense current flowing in the safety leg and use that to disconnect all three mains connections with a 3 pole relay. I had less than zero chance of getting this UL approved, because I didn't bother submitting it (the UL likes their safety ground bonds).
My general advice now for practical guitar player safety is to cap couple all the grounded metal parts inside the physical guitar. A properly sized cap will be adequately quiet and prevent human exposure to lethal currents in case of exposure to mains voltage coming from any direction. /TMI]
PS: I am sensitive to this because while I was working at Peavey we got sued over an electrocution death when a player got between two Peavey amps, where one was plugged into a RPBG (hot safety ground) outlet. This mis-wired outlet effectively energized one guitar amp chassis. The other properly grounded amp provided the electrocution path. We won in court but the musician is still dead.
