JH636 Power supply repair.
rlaury
Nashville, Tn
Hi All:
Just had the power supply go down on our 636. This happens from time to time. Normally I replace the 2n3055H's
that were shorted and it's done. But today I had to use the MJ15015 because the 2n3055H's are not available.
The MJ15015's are a high power 2n3055 and should work. It doesn't blow them up are anything. They just don't regulate.
Anybody had this problem?
Any advice appreciated.
rlaury said:
Hi All:
There's just no reason why it shouldn't work. It's something else. Check your connections; it's so easy to have a solder ball touching the heatsink... Good luck!
abbey road d enfer said:
rlaury said:
Hi All:
I can't make them work. 203055H will arrive tomorrow and I'll find out why. Maybe too much current gain. The MJ15015 is 180W device.
