The other thing to consider here is the share of gain for a given fixed amount of gain from the preamp. Ie. the opamp will be working harder for a fixed amount of gain, if you use a lower ratio transformer, as the transformer will be providing a lower portion of the total gain.
This might be worth considering if you want to really drive your discrete opamps, or if you don't.
Also, the noise figure should be different when using different ratios.
