mattmoogus
Ok so the power supply or your wiring is not delivering 48V to the BA PCB. So unplug the PSU and measure its output voltage, if its 48V recheck your wiring until you find the break.
M@
M@
Also check the transformer wiring (if its a 1:4) and that there isnt extra solder thats run down the legs (if its an OEP) and shorted anything out.
They can, its possible that the pot was a dud and you can also damage them by applying too much heat or soldering to the wrong place on the tabs. The way to check is to remove it from the circuit and measure the resistance between the middle pin and either outside pin.
How do I wire it up with a 10k resistor and a power led?
When using a Firebox for pro level input and to eliminate the built in mic pre section in your firebox you need to plug into the line in 3 & 4 TRS on the rear panel and make sure the Input level boast for Line in 3 & 4 in the software screen is off. The TS in the middle of the XLR's on the front are unbalanced DI inputs and should not be used.I've got a firebox, same as whoever it was having problems with that combo earlier in this thread. The firebox is balanced, perhaps not set to +4? Who knows, I'll send them a mail.
I've tried it in other setups too(balanced +4) but it's pretty much the same, distorts way too easy. DI's bass for instance distorts with the pad in and the gain at zero. I mean, should you even get a signal?
Metal Film can go open circuit on power up surge with no external sign or actual fault. 1/4w or 1/2w Carbon will have no trouble with the power up surge and will char if there is a fault.anything special about the green resistors thought i read somewhere they were carbon instead of metal film. any reason i can't replace with metal film
:grin: No that is fine but keep the wires twisted together and as short as possible.I'm a huge fan of the JLM stuff since I built the dual 99v. Amazing. Now I'm thinking about putting together a few of these and I have a question about the Hybrid opamp. It seems to me that it would be useful to add a switch on the front panel wired to the two pads which change the opamp from class A to class A/B. Is there anything about this idea which would not work? Would it be bad to switch the opamp while the unit is powered up?
Yes it will work without it but the frequency response will be way brighter and the pre will probably oscillate at high gain.yea, well, uhmm, it seems i didn't get rl installed [27k or 100k]
could that be the problem sounds so nice now, should it even be able to work without it
Only faulty pots we have seen so far is ones where the wires are soldered to the leg to carbon track rivet holes which should never be done as flux can get into the pressure joint and insulate it making it permanently open circuit. Only ever solder to the leg. But there could always be a faulty one out of the 1000's we have made. Sent you a free 10k rev log pot in today Air mail to get you going. Your email bounces my replies I have been trying to send you.There was a bad solder connection. However, one of my 10k reverse pot's doesn't seem to work. I get a constant signal at the lowest volume (as if the pot is not hooked up). But everything is wired the right way. I am certain of this. It is just like the 4 channel I just finished (sweet!). I guess my question is can 10k reverse pots go bad?
The undrilled JLM front panels do not have the 4 holes in the corner as universal cases have these holes in slightly different places. To drill our front panels tape over the front of the panel with 50mm (2") white paper tape like painters use as the centre punch markers can still be seen through the tape. Lay the blank front panel on top of the JLM one and mark the 4 mounting holes on the tape. Centre punch all hole centres including the 4 mounting holes and drill all centre punches out with a 2.5mm pilot hole before drilling with the final holes size drill. Finish holes on the front and back of the front panel with a deburring tool or large drill bit. Then peel the tape off and the panel should be perfect and ready to go.Is the case included with the front panel? I usually order cases from par-metal here in the states, and all the cases I order seem to have the holes in front for the front panel to be bolted on. I do not see these bolts/screws on your fully assembled unit from front panel to case.
Where would I get this type of case in the states to work with your front panel? Do you also sell cases?
The JLM111DC is adds very little tone difference but can give you an extra 6dB of gain when wired 1:2.how does the sound of the 1:4 + 99v change by adding a 1:1:1 to it. What characteristics I mean?
The JLM111DC is adds very little tone difference but can give you an extra 6dB of gain when wired 1:2.[/quote]how does the sound of the 1:4 + 99v change by adding a 1:1:1 to it. What characteristics I mean?
No. The Baby Animal has the opamps output sitting at half of the single 48v power rail so the output cap can never be left out. Otherwise the low DC resistance of the transformer would short the opamps output to the 0v and fry the output protection 51R resistor. This basically goes for all one power rail designs including the Hampton Jfet if it is the one I am thinking it is.Do you omit the output coupling cap, since the 1:1:1 is gapped? I'd really like to use it that way in a BabyAnimal and maybe my Hampton-design JFet pres.
