That's a 5K variable resistor (adjusted to 4K7)hanging on the impedance pot. Its all i had going at the time
Either 5k or 4k7 will work fine. Nice case recycle and I like the wild dial pattern around the knobs.
This pre will get lots of use recording drums and electric guitar, it has some sweet low mid warmnes going on.
So much better than my presonus pres!
Im addicted... Thanks Joe and mat
:grin:
I think the switch with my kit is DPDT (it has 6 connections in rows of 3). How do I wire this switch using a LED (which side of the LED connects to where). I read earlier descriptions in this thread and the response was to wire the top and bottom connections. This doesn't make sense for the switch I have in my kit. I could be having a brain fart though.
Also what type of wire is recommended for this purpose?
Take the 48v from the power supply to one of the centre tags. Then a power wire to all BA 48v from the tag directly under it. That will make the BA's on with the toggle turned upwards. Join a 10k resistor to the BA 48v wire and then the other end of the resistor to the Anode of the LED (long leg) and then take the cathode of the LED (short leg) to 0v. Done.
I was a bit worried with the hybrid as the LED didn't go off in A/B but then I noticed I soldered the wrong two squares together. I think I soldered the DC servo option instead of the A/B opamp. The two squares in the red circle are the right ones. Correct me if I am wrong
That was because in the photo you sent me you had a 1N4007 Diode backwards.
In the photo below the top 2 square pads are servo on when soldered together.
The bottom 2 square pads are Class A/B when soldered together and LED is off.
ALSO WHEN USING HYBRID WITH BA PCB LEAVE OFF 47uF cap on the opposite side of the PCB to the LED. As this can override the power supply filtering and let noise into the pre.
One more thing. Is there any special reason of bending the NPN and PNP. I left the NPN a little more in the air as the PNP is down holding the LED tight. I noticed also that they tend to become pretty hot. Is this OK?
They will be hot but the one with the LED should be flat with the LED legs short for the thermal coupling to work best.
I need absolutely a gain knob that makes my preamps going between 0 and full gain, on the OPA 2634 with OEP put at 1:12.9 even with the pad on it was still too loud on certain sources with the gain pot fully CCW !!
The sound card was a MOTU 2408 (old model), with 8 unbalanced inputs, but I can't find the manual to check if the input line level of the sound card is the problem or something else.
An other idea is to put a variable pad or an output attenuator ?
A gain pot should with the pad switched on get you close to unity gain at minimum setting. But with the OEP on 1:12.9 and giving 22dB gain + 6dB from the opamp if using 99v or 12dB if using OPA2604, NE5532 you will need to change RPad to 39ohm to make a 28dB pad for 99v and 22ohm for 34dB pad. From memory your Motu 2408 Mk1 clips at +4dBu so to make it into a pro level unit you should add a Pad into the input plug of 2.2k in series with the input and 470R across the Motu input to ground and make a -14dB pad which would give +18dBu 0dBFS like Digi001 and 002 and RME etc.
Purusha got the kits ok. Seems the main problem is the millmax pins with the fat collar at the base do not leave enough room for the 51R in between them at PCB level. Forcing the 51R in will just chip the paint of the resistor exposing the metal cap on the end of the resistor which will short the 51R or the opamp output or 0v or both at the same time. If using these Millmax pins leave the 51R resistor about 5mm above the PCB where the pins are thin again. The pins we supply with the kits are fine with the resistors hard against the PCB.
