JLM Audio
Yes they will work fine as 1:2 or 1:3.Matt or Joe, i'm awaiting a pair of boards impatiently....Now i have 2 API output transformers by CJ could this work fine in the BA?
To make sure you are getting the primary of input transformer test with a ohmmeter between pin 2 & 3 of the input XLR with the pad off and you should have about 20 to 50ohm depending on transformer and between pin 1 & pin2 6.8k and pin 1 & pin 3 6.8k. If you still have no luck send to my normal email address clear well lit macro on photo's so I can see if I can spot the problem.I'm getting a good signal through 3 channels, but no signal at all through one channel. I've got proper voltages at the opamp pins and high resistance between each pin and 0V. I've got conductivity between my xlr pins and the board. What other areas would you recommend me troubleshooting?
This is for New Baby Animal Dual or Dual 99v only. You will not get this out of a normal Baby Animal.It can with a JLM14 and JLM111DC output transformer do 86dB of gain
It can, or it will?
Wire the API primary to +out and 0v and use the API as 1:2 or 1:3 for more gain.Hi Joe, i received my Baby Kits yesterday they are ready to be racked but still got one question as i have 2 API output transformers that i want to use with the BA. Is there anything i should know or should i dive? ]
If you have used the 27k for the input transformer then yes there will be a 10k left over. Otherwise you will have a 27k left over.One more thing.....i have a 10k resistor left by kit, is that cool??
The JH 990c needs no change but the 1731 will need the on board opamp reg fitted to cut the voltage down.For the record: i'm gonna put one 990c by JH and the other a 1731....again anything i should know before doing it??
