glide 1
Hi Matt Joe,
Please check your mail, just emailed you about some info on the BA2's, thanks
As long as there is not dead short on the output of the opamp or the 51R resistor from the opamp output it will be very had to do damage to the opamp. So the best test before power up is to use a multimeter and check that all opamp pins except -V pin do not show lower than 1kohm to 0v.I don't think you'd fry your DOA's as long as you check your voltages without them in first. Just make sure the voltages are what they should be for the configuration you want. There is a table on the JLM website just for this.
What voltages are you seeing over the BA PCB that is not working with the 990C plugged into it? Look for ones that are different to the overlay on the web site as this will give us the info to work out what is going on.I've got one channel that won't work with a 990c opamp. It works fine with the 99V. That 990c works fine in another channel. Any ideas as to what could be the problem?
GA80980 Tamura input transformers are from a Yamaha PM2000 channel strips and in there design they use a RL = 150k RZ = 2.7k CZ = 470pF. You may need to add a CL of 100pF to 390pF if you get oscillation at full gain with a 99v.
GA80071 Tamura input transformers are from a Yamaha PM1000 channel strips and in there design they use a RL of 3.5k (4.7k || 2.2k + 3.3k + 8.2K) RZ = Not Fitted CZ = Not Fitted. You may need to add a CL of 100pF to 390pF if you get oscillation at full gain with a 99v.
