bluezplaya
Well that's what I have are the Fabio 2520's so I will leave it alone. :grin:
Adam
:sam:
Adam
:sam:
I'm not sure if you are referring to just the op-amps, or complete circuits with different input transformers that have different impedance ratios.John Hardy i find it to clean to my ears, good on all frequencies.
BB OPA2604 and Signetics NE5532, was hard to tell the difference but the main thing it's their gain, higher that JH 990c!
The gain difference between any single 99* type and the Dual DIP IC will be 6dB in a baby animal mic pre with no output transformer due to the other half of the DIP IC opamp being used as a balanced inverting stage which adds 6dB. If you want to make your JH990c opamp baby animal pre the same gain just change Rg from 68ohm to 33ohm.BB OPA2604 and Signetics NE5532, was hard to tell the difference but the main thing it's their gain, higher that JH 990c!
i just got the dpdt switches that i ordered for my BA pres...and guess what..
I ordered the wrong type (24 of them)
I ordered the type with straight legs...damn!
And now i cant find any place in sweden that sells the other kind cheap. Except for one place, but the switches they have there dont have any threads , so i cant mount the pcbs to the faceplate with those.,,, I should have just gotten everything from JLM and not just the pcbs and iron.
Anyone know where i can get these kinds of switches for cheap in europe?
We always use Salecom switches unless we have not been able to get stock and all new BA kits have Gold contact ones that we have had custom ordered direct from Salecom by the 1000s. We can supply them separate for $4AUD. If you need them just send a email to my normal email address.I'm not sure which ones your have but Joe has switched to the brand I use called Salecom which I personally believe are of better quality than the older switches, but I may be biased
The Salecom ones he is using now are T8021L Series.
Good to see B* gear being used for some thing useful :wink:The chassis came from an B* unit, with XLR's and 1/4 already drilled...it made well the job.....
Hope i did well representation of the boads made by JLM!
BTW: i'me getting at least 4 more!!
