ChrioN
Any updates on the BADs? Release date?
Hi Joe and Matt,
Would like to thank you for a wonderful sounding pre, we had a few minor problems with assembly (our mistakes of course)and joe responded to our emails promptly.
We compared the BA2 to Api's, Adesign P1, Seventhcircle N72, Avalon, etc and it is right up there with quality, on some sources like bass guitar and vocals, even better. I would have to say it sounds closest to the N72 with extended lows and highs.
A big thumbs up....we look forward to getting more channels in the future.
glide 1
All I can say is WOW! What a great and useful pre.
There are no buzzes and the pre is dead quiet, even at high gain settings. Joe did a great job with this one, and I hope to be getting a few more channels soon
Final BAD PCB's are due back around the very end of February. I will have final pricing up before then on the Baby Animal web page. We have had the BAD prototype working up to 93dB of gain with 2 x JLM99v and JLM14 and no output transformer and it has been running stable now for some time.Any updates on the BADs? Release date?
What ohms do you get with the BA off and Pad off between input XLR pin 2 & 3 (20ohms) and between pin 1 & 2 and pin 1 & 3 (3.3k). Also worth checking the output pin of the opamp is not shorted to 0v by 0 or 51ohm.I just finished mounting my first BA (JLM 14 99V) in its case and plugged it in. I seem to have low output. I noticed the pad switch wasnt working and then realized I hadnt put the 120 ohm res. in. I soldered that in and now it works. I tried it with a 58 on vox and I have very low output. I checked my voltages against the chart and the 2 inside @'s on the primary side as well as the traces that attach to them show 0v with phantom on or off. Other than that every thing looks fine. Any ideas?
I also tried a acoustic with a built in preamp into the DI. I have to crank it way up and it's distorted.
48.83 (dc in side)and 48.67What voltage are you getting on the each side of the 10ohm resistor?
input pins 2 & 3 is (28ohms) 1 & 2 is (3.8K) and 1 & 3 is (3.8K)What ohms do you get with the BA off and Pad off between input XLR pin 2 & 3 (20ohms) and between pin 1 & 2 and pin 1 & 3 (3.3k). Also worth checking the output pin of the opamp is not shorted to 0v by 0 or 51ohm.
