rattleyour
Sweet I love the Go Between kits so I bet I'll love+ the new version.
Skipwave is right about the 24v bias is missing.
And this is your problem as you have the input transformer secondary tied to 0v instead of +24v half rail
which is used to bias the +in on the opamp to half volts
which then holds the output of the opamp at half volts so it will all work.
So guys, ideas on how I should get the "master sum/makeup gain" BA's to amplify this signal without an interstage transformer? I've not fitted the CZ, RZ,RL, or CL to them, and insert the signal at the top of the CL pad which goes to the + in of any DOA or opamp. Using tested good JLM Hybrids for this, I get a red LED, then it flickers for some time, then goes off.
