I have the cases and some aluminium angle and am ready to mount the output transformers.
Are you having any problems with hum mounting the output transformers like this?
My tech suggested mounting them at 90 degrees to each other to avoid hum fields. It doesn't look anywhere near as tidy as this method but is it worth doing?
There is no hum problems mounting them like Knarleybass has done as none of the transformers are power ones. I think your tech means he is worried about coupling between channels but just keep the spacing about 1" or more apart and it will be fine.
or does the LL1578"XL" version have definite advantages ?
Not really as the normal version has enough headroom and you want some colour from the transformer. Normal LL1578 is great.
is there a reason to prefer an original 2520 (api) or JLM 99V
in comparison to the Hybrid ?
A 2520 has tight low end and is very hard edge sounding in the high end due to the large odd harmonics.
The 99v is the complete opposite with a fat low end and silky high end.
The Hybrid in class A/B has tight low end and has the fast snap of the 2520 without the high end distortion.
The Hybrid in Class A still has the tight low end but is more like the silky high end of the 99v but still a bit faster sounding.
I find it very confusing there is no documentation supplied. I am building the BAD with the jlm input TX. Where can I find info about what parts are omitted with this set up?
The BAD = Dual99v changed to run of a single 48v rail. It is the same as a normal BA kit. You fit all parts in the kit which should leave a 10k and 27k, 120R and 2 x 270R. RGAIN1 & 2 = 270R, RPAD = 120R. RL = 10k for JLM14. RL = 27k for OEP262A3C. JLM14 & OEP262A3C require no CZ or RZ. The gold pins that hold the 99v are only pushed into the PCB until the bottom of the pin is flush with the bottom of the PCB so they hold the 99v over the parts under it. Ceramic caps under the 99V are laid on there side. THE BAD has a dual 10k rev log pot which wires to the 0v which goes to both pots and G2 goes to one pot and G1 to the other half of the pot. Just like the BA overlay shows but done twice. The BAD also has a spot for a trim or output volume pot marked O = out, I = in and 0v. If not using this pot wire O to I. This point can also be used to insert a passive eq circuit like a Pultec etc.
Don't forget if you have any questions while building feel free to email me.
Have a great Xmas and New Year everyone :wink:
