Hi Joe,
How close to the Forsell opto sidechain is your comp? Looks like you went with a fullwave rectifier, and only two opamp stages (one 2604). One inverting and one non, each driving a fullwave bridge into the LEDs?
It's as though you read my mind; I was just figuring out how to integrate the Forsell opto with a BabyAnimal mic pre. I'm making a small box for traveling with an mbox mini. I had settled on using the LDR as the shunt R in a U-pad on the output.
All MAC info is here
http://jlmaudio.com/user/viewtopic.php?t=63&postdays=0&postorder=asc&start=0
i haven't put the api style cinemag OTs in yet but there shouldn't be any mods for putting them in right?
The Cinemag output transformer should be connected up just like the JLM111DC. Remember a OPA2604 cannot drive a 150ohm load so if using a transformer use 1:1. With the Hybrid 1:2 and 1:3 ratios are fine.
HAVE A PROBLEM I CAN'T SOLVE ON MY OWN
One of my BAs with 1:4 + 99V + 1:1:1 doesn't work anymore.
There is almost no sound coming through, just a lot of noise.
I noticed the noise increases when I turn my variable impedance
knob CW. Otherwise the V seem to be correct and Opamp works OK.
Any suggestions?
If the noise goes up when the impedance and/or the gain control are turned up all the electronics is working fine. And the fact you can hear a slight bit of signal it sounds like you have one open leg of the balanced input signal. First thing with a ohmmeter check that you can see the JLM14 input which should be about 20ohms with the 48v off, pad off measured between the input XLR pins 2 & 3. IF not check the wiring from the input XLR to the +/- in on the BA PCB. The next set of contacts in the balanced line are the IDC10 socket. So if there is a DI plugged in remove it and place the 2 jumpers in the IDC10 header. IF this fixes the mic pre the switch in the DI socket is open circuit. The signal then goes to the pad switch and then the phase switch. You should be able to measure the JLM14 input of 20ohms on the top to legs of the phase switch. If you cannot measure the 20ohm here go straight to the red and green wires on the JLM14 and see if you see 20ohm between them.
I really like the sound of the OEP input + OPA opamp, but I don't think it will be enough gain?
With the OPA opamp or Hybrid RG can be as small as 22ohm which will give you the maximum gain possible. Use OEP on low ratio (1:6.45) will give 18dB + 53dB from gain stage plus OPA has another 6dB from the second inverting stage = 18 + 53 + 6 = 77dB. If using Hybrid you will get 71dB or 77dB if you use a JLM111DC output transformer wired 1:2.
but from what i've heard you should use low ratio parts to get 150ohm minimum, does it work to have the OEP in with high ratio and still get 150 ohm minimum load?
OEP262A3C is always best in low ratio (1:6.45) with 27k secondary load this give 600ohm input impedance. If you do go to high ratio the input will be 150ohm.
I'm also thinking about using the Lundahl, what's u're suggestion?
The LL1538 is so clean it is almost like not having a transformer. But the LL1578 starts to get some nice warmth which is why you want a transformer in the first place (Well at least for rock music :grin: )
[Lundahl LL1578(1:10) + Hybrid + 1:1:1 out trafo(1:2)
Lundahl LL1578(1:10) + OPA2604 + 1:1:1 out trafo(1:2)
OEP262A3C(1:12,9) + Hybrid + 1:1:1 trafo out(1:2)
OEP262A3C(1:12,9) + OPA2604 + 1:1:1 trafo out(1:2)
Lundahl LL1578(1:10) (21dB) + Hybrid (43dB with RG = 68R) + 1:1:1 out trafo(1:2) (6dB) = 70dB RL = 15k for 150ohm RL = 60k for 600ohm input impedance.
Better option is
Lundahl LL1578(1:5) (15dB) + Hybrid (53dB with RG = 22R) + 1:1:1 out trafo(1:2) (6dB) = 74dB RL = 3.9k for 150ohm RL = 15k for 600ohm input impedance. Variable RL = 3.9k in series with 50k log pot. Range 150ohm to 2.1k
Lundahl LL1578(1:10) (21dB) + OPA2604 (49dB with RG = 68R) + 1:1:1 out trafo(1:2) (cannot use 1:2 output transformer on OPA as it can only drive a 600ohm load) = 70dB RL = 15k for 150ohm RL = 60k for 600ohm input impedance.
Better option is
Lundahl LL1578(1:5) (15dB) + OPA2604 (59dB with RG = 22R) = 74dB RL = 3.9k for 150ohm RL = 15k for 600ohm input impedance. Variable RL = 3.9k in series with 50k log pot. Range 150ohm to 2.1k
OEP version are the same as above lundahl version plus about 3dB of extra gain and also best used on low ratio 1:6.45 and RG lowered to 22R when using a Hybrid or OPA2604. RL = 6.2k for 150ohm RL = 27k for 600ohm. Variable RL = 6.2k in series with 100k log pot. Range 150ohm to 2.4k
